  • s5unty
    • May 2016
    Is it possible to download maps from zabbix with command line?
    I would like to integrate map.png to Grafana.
    If I use the map link[1], other Grafana user who were not users of zabbix could not see the map image.
    So I have to use a real image file instead of the map link[1].
    I have tried the zabbix api "image.get", but it doesn't work for me.
    The 'curl' command line show me "You are not logged in".
    Is there any other method?
    Thanks.
    [1]: http://thezabbix/zabbix/map.php?sysm...severity_min=0
  • viktorkho
    • Jul 2013
    • 90
    If there is no more proposes..
    1) Open map in your webbrouser
    2) Drag'n'drop map.png to to create one more tab with this png (or select somthing like "Open image in new tab" in context menu of image)
    3) Use image's url in address-bar
    This image will up-to-date while your session is alive (see 'sid' in url). So if you can emulate this behaveour in your application, you will solve you task..
    • s5unty
      • May 2016
      Thanks viktorkho.
      Solved this problem (reference).
      It works in version 3.0.
      wget --save-cookies=z.coo -4 --keep-session-cookies -O - -S --post-data='name=(a zabbix username)&password=(password)&enter=Sign in&autologin=1&request=' 'http://example.com/zabbix/index.php?login=1'
      wget -4 --load-cookies=z.coo -O result.png 'http://example.com/zabbix/map.php?sysmapid=1&severity_min=0'
      • viktorkho
        • Jul 2013
        • 90
        Thanks s5unty (and Michael Tabolsky) for very usefull wget..
        • naigamo
          • May 2015
          How to wget zabbix map version 3.4
          Originally posted by s5unty
          Thanks viktorkho.
          • cwhite
            • Aug 2015
            • 47
            +1 on broken wget in 3.4
            We had wget working simply up to 3.2 now it seems instead of .png file we are getting the raw xml/html returned. Did notice the url format has changed slightly in 3.4 but updating and trying
            as example
            wget -O /var/www/wiki/images/6/64/MapHBC.png "http://IPADDRESS/zabbix/zabbix.php?action=map.view&sysmapid=4&severity_min =0"
            returns no png
