Monitor a directory, only a specific file should exists.
  • juanpablo
    • Feb 2023
    I would like to monitor a directory, only file1.txt should exists, all other should give an error.
    Example.
    /tmp/dir/file1.txt
    I can do:
    vfs.dir.count[/tmp/dir/]
    if count is more than one, then give an error.
    Is there another way? like:
    1. Get the list of files inside the directory, then compare, if file is not equal to "file1.txt" then throw an error.
    2. Get the count of files in the directory other than "file1.txt", count should be zero.
    any help is appreciated.
    Thanks.​
  • Hamardaban
    • May 2019
    • 2714
    The vfs.dir.count key accepts regular expressions as parameters describing which objects to consider and which not.
    vfs.dir.count[dir,<regex_incl>,<regex_excl>,<types_incl>,<types_ excl>,<max_depth>,<min_size>,<max_size>,<min_age>, <max_age>,<regex_excl_dir>]​
    You can configure your item to count other files by excluding file1.txt from the count.
