snmp trap lld
  • cnhome1
    • Feb 2023
    snmp trap lld
    Is it possible to do LLD item creation from SNMP TRAPS ?
  • Hamardaban
    • May 2019
    • 2714
    Yes - it is possible.
    How to do it depends on the data in the trap.
    Your task is to convert this data into json suitable for LLD
    • cnhome1
      • Feb 2023
      Thanks for the reponse, the problem is the dicovery rules only allows a type of SNMP agent (so it expects to read values) and not SNMP Trap (as i have set the main item to). The device i am working with only generates traps and does not allow reading of the device alarms. So I need to do this specifically when a trap is received by zabbix Click image for larger version
      • Hamardaban
        • May 2019
        • 2714
        I'm sorry - I looked at the list of possibilities incorrectly.
        You're right.​
          Yes, you cannot have discovery source directly as a trap, but you can have regular trap item and point your discovery to that item (type dependent). and create your items also as dependents from that master item. Only downfall here is, that with the first trap you get items created and only with the second one populated..
          • Hamardaban
            Hamardaban commented
            That's right!
            I completely forgot....
