How to monitor mounted filesystem via zabbix active check
  • jhasaurabh
    • May 2016
    Dear all,
    I have my multiple instances running behind nat and I am running active zabbix agents on these instances to monitor them. I don't seem to get the mounted filesystem info.
    Can anybody please help how to get mounted filesystem details in active check mode?
    I am running zabbix server version 3.0 also the agent version is 3.0.
    Thanks in advance.
    Saurabh J
  • DmitryL
    • May 2016
    • 278
    Hello jhasaurabh,
    Have you created item on host that checks your filesystem?
    If yes:
    Do you get any errors about item in frontend, agent/server log?
    Do you get reply if you use zabbix_get from server side?
    zabbix_get -s <ip> -k "<key>"
    • jhasaurabh
      • May 2016
      Hi Dmitryb,
      Thanks for your reply.
      My zabbix server can not reach the instances because they are behind NAT, that is why I am using active checks to monitor my instances.
      The command you gave times out when I run it against one of my instances behind NAT.
      Thanks,
      Saurabh J
      • DmitryL
        • May 2016
        • 278
        So if i understood correctly other active checks on that host are working fine?
        Can you attach screenshot with item configuration for your fs check?
