hi .
i am looking for a way to read and graph the contens of this file .
OK
OK: 48007.699 8.666 6.332 9.825 | sr=48007.699 lt=8.666 pd=6.332 md=9.825 sd=-0.033081 dgrams 65514798 missing 184359 excessive 257 late 37423
the content is from a Datum GPS timing 10Mhz/1pps unit.
i found the item to check if the file on the remote client is present ..
but i want to graph the values.
the first value is a trigger is the device is OK/WARNING/CRITICAL
the second line is first the same as the first line and after the "|" the values to be graphed..
any one kan assist me to make this possible .
grt Joost
OK
grt Joost
