mysql monitoring with Template DB MySQL by Zabbix agent 2
  • ezols
    • Dec 2021
    • 33
    Hello, I'm having issues configuring mysql monitoring on zabbix 5.0.0 on remote host which uses zabbix-agent2 client.
    I have added template Template DB MySQL by Zabbix agent 2 to host.
    I have added username, password and connection param.
    ​And this is where im stuck, when I check on item i see that it try's to connect with wrong username, with "3306"
ID:	460441​Any advice's what should i do more?
    Thank you in advance.
  • ezols
    • Dec 2021
    • 33
    Issue is gone on zabbix 6.4
