Wrong time on graphs
  • gepp87
    • Mar 2023
    I have i little problem witch graphs on zabbix, Under the chart, he has time 1 hour earlier than the actual, hovering the correct time in the same place.
  • Michał Czerniakiewicz
    • Feb 2023
    • 17
    Hi gepp87,
    Please check the timezones on both your instance hosting Zabbix server and front-end and the host from you are collecting the data. All clocks have to be synchronised with NTP.
    Kind regards
