Is there a way to use a host item element on a map? E.G. status of disks?
  • dkgame
    • Feb 2022
    I'm attempting to do some nice simple "at-a-glance" maps for my colleagues to be able to see the status of stuff like disks, fans, psu etc. on server hardware in our DCs to save having to do manual visual checks.
    They're all Dell devices, and all using DRAC which works nicely, I'm getting the status info being polled, however when it comes to putting them on a map, rather than have multiple dashboard tables of the items, I'd like to put them on an actual map as an element. We can add an image, another map, a host itself, a trigger or a host group but there's nothing to add the status of an element of the host. I'll see if I can do something using triggers, but I'm not sure it'll do what I want.
    Is there a way (or a plan to add it) to add a simple status of an element onto maps?
    Thanks!
  • Michał Czerniakiewicz
    • Feb 2023
    • 17
    Hi dkgame,
    Please find the video tutorial on how to set data like you want presented in Zabbix network maps(https://youtu.be/jtLUGgMeh3E). Dell devices has already a lot of integrations templates so I don't see a problem to find and use the already built-in Keys in map element configuration.
    Kind regards
