Monitoring Disk IO errors
  • wooway
    • Mar 2023
    I am looking for a way to monitor disks IO errors using discovery key vfs.dev.discovery.
    However, I try something like vfs.dev.read.errors[{#DEVNAME}] it says Unknown metric vfs.dev.read.errors.
    Is there a way to monitor for disk io errors?
    Do you see something like "vfs.dev.read.errors" in item list? No? So, why do you expect it to work?
    If you want to monitor something that is not built-in, then you should think, who would you obtain that data manually, from command line for example. If you can find such a command/series of commands, you can script this, and run it as UserParameter https://www.zabbix.com/documentation...userparameters
    • wooway
      • Mar 2023
      I appears that I can use zabbix key log[/var/log/messages,"I/O error"] to find what I want. Thanks
