For reasons I am unable to cleanly use client auto registration to get my hosts into zabbix. So as a result I have a Puppet recipe that applies a value to the HostMetadata field in the agent config, the default of which is 'other'
If a host is tagged as 'Other' It goes into a host group that provides only basic monitoring and needs to be manually reviewed to make sure that its main config is correct or in some cases simply put into another host group.
Is there a way to create an alert every day if there is a host in a host group?
