Separate frontend on proxy
  • jzoltan
    • Feb 2023
    Hello!
    Is it possible to install a php-frontend on a proxy that displays and handles information of hosts that are beind monitored by that certain proxy, while the frontend on the main server that has access to all data from all proxies is unchanged (ie. it still sees the data from the proxy that has a separete frontend).
    Thank you very much in advance.
    No... that is not possible.
    • jzoltan
      • Feb 2023
      That is unfortunate... thank you.
