Cannot execute script: Error: maximum count of HttpRequest objects was reached
  • wusj
    • Mar 2023
    Hello.
    I ran into a problem while using the Consul Node template via HTTP. I can't get any responses about local service. I get the error:​
    Error: maximum count of HttpRequest objects was reached. Check debug log for more information
    I enabled debug logs, but I didn't see anything that could help me. It looks like it is an issue related to environment data, according to sources. How can I solve the issue? Or may be change the envieroment data?​
  • wusj
    • Mar 2023
    I figured out why I get the error. I have 11 consul services but zabbix has limit 10 per http requests per one JavaScript script. Is it possible to increase this limit? I have up-to-date consul template by zabbix gitlab
    • radix
      Administrator
      • Apr 2017
      I hope will be fixed soon:
      Bug report: https://support.zabbix.com/browse/ZBX-22488
      Caused by: Limitation of HTTP header counter and Curl instances which I believe before cause of allocation of large memory chunks​
      System and Network administrator
