Item json path preprocessing issue
  • ezols
    • Dec 2021
    • 33
    Hello, could you please advise whats wrong.
    I have created an item with preprocesing on json path - $.value[0].timeseries[0].data[59].maximum
    I have tested the step:
    I got the value what i needed, but when i check on item i have these problems:
    Preprocessing failed for: "timeStamp": "2023-03-09T13:40:00+00:00",
    1. Failed: cannot extract value from json by path "$.value[0].timeseries[0].data[59].maximum": invalid object format, expected opening character '{' or '[' at: '"timeStamp": "2023-03-09T13:40:00+00:00",'​
    I have attached json.txt in which is json content from which im try to retrieve last(59th) value of "maximum"
    I have validated json path in validation tool and got the needed result:
    Could you please advise whats wrong?
    Thanks. ​​
  • Answer selected by Markku at 02-07-2024, 16:25.
    D-with89
    • Jul 2024
    Hi
    I managed to find out that is actually works, only the test buttons returns error, while the latest message returned the correct value. I have created the trigger with it and know I get the notifications properly.
    I am pretty sure it's JSON data, I have tested it with different validators without any issue.
    David
      yeah, the example data seems OK.. That "timeStamp": "2023-03-09T13:40:00+00:00" is not from example data... Are you sure that if you pull that data from host, it is actually complete and correct...Maybe its broken json....
      • ezols
        • Dec 2021
        • 33
        im not 100% sure if json is not broken, looks ok, but to avoid this i just got needed data directly on host with the same json path and got needed results, no errors on host about timestamps
        az monitor metrics list --resource "" --metric cpu_percent --aggregation maximum | jq '.value[].timeseries[].data[59].maximum'
        post can be closed, workaround implemented.
        • Theolude
          • Apr 2011
          • 13
          I've exactly the same issue.
          I produce a JSON dataset from a webservice called by Zabbix server.
          The JSON dataset is correctly build by the webservice, i can get it by different ways and it's always OK.
          When i try to test the JSON string with Zabbix pretreatment associate to the item, i've got the right value, and no errors in JSON.
          Nevertheless, the server console warn me that ... as he's not received the JSON ...
          I'm lost, and need help
          Best regards, Théo
          • D-with89
            • Jul 2024
            Hello Everybody,
            I have the same issue, and I cannot find the solution... Does anybody managed to fix it in the meantime? I use the 7.0 LTS version on Ubuntu 22.04 with MySQL (native version, no docker)
            Thank you in advance.
            Best regards,
            David
            • Markku
              • Sep 2018
              • 1784
              The error message says that the item input data is not JSON.
              Markku
              • D-with89
                • Jul 2024
                Hi
                David
                • NLukas77
                  • Jul 2024
                  Hi, I have solved the same issue. JSON seamed OK, JSONpath Evaluation said OK, but zabbix wrote still error code. I have used javascript in preprocessing for the masteritem.
                  var cleanValue = value.replace(/^\uFEFF/, '');
                  return cleanValue;
                  Issue is solved now
