Size of Folder
  • waldoo09
    • Mar 2023
    Size of Folder
    Good morning,
    I monitor the size of a folder but I receive a value in bytes. I would like to have the size in Gigabyte because when we look at the size of the folder we see that it does not really correspond to what zabbix returns​
  • Michał Czerniakiewicz
    • Feb 2023
    • 17
    Hello waldoo09,
    You can achieve it by adding "Custom multiplier" to your preprocessing steps of your action. Please find the example below:
    Is the size of the monitored directory different on the host than Zabbix presents?
    Kind regards​
      Set unit to B and it will show you automatically converted value (K, M, G etc..). https://www.zabbix.com/documentation...fig/items/item
      There is a difference in b and B..
