Monitoring VMWare - error data datastore
  • brenoacp
    • Jun 2016
    • 26
    Hello everybody, We are monitoring a VMware cluster, and we are error to collect the datastore only.
    We cloned the original template and apply to the VSPhere host.
    The error is: "Specified Parameter Was Not Correct: Queryspec.starttime, queryspec.endtime"​
Name:	2023-03-10 09_25_42-Clipboard.png
    I already have another monitored cluster without any problem.
    Has anyone been through this situation?​
    Best regards,
    Breno Padovan
  • Dileep
    • Apr 2022
    Hi Breno,
    I'm also facing this issue same like you for one cluster its working fine but one having same issue.
    If you Found any solution/Cause meanwhile please let me know.
    • Dileep
      • Apr 2022
      Hi Breno,
      are you getting this error as well?? along with this error : "Specified Parameter Was Not Correct: Queryspec.starttime, queryspec.endtime"
