Hi guys,
I'm installing database and zabbix 3.0 in new VM.
Based on the instruction, I should import 3 sql files into the database. However,
in the /usr/share/doc/zabbix-server-mysql-3.0.1, i only can find 1 create.gz and after extract is only 1 create.sql .
I would like to check is it in version 3, they have combined 3 files into 1 or the files is located at other location.
Kindly advise. Thank you very much in advance.
