Macro Functions in Item Keys
  • florian.becker
    • Mar 2023
    I'm trying to setup SNMP monitoring for one of our Firewalls. The problem is that the Firewall returns non consistent names (from SNMP discovery) for VPN tunnels and constructing a unique item key is not possible. However a unique key can be constructed using regex. When trying to use macro functions in the item key I get the following error:
    The same macro functions seems to work for the item name.​ Is this intended by Zabbix or am I missing something?
  • Answer selected by florian.becker at 14-03-2023, 15:51.
    cyber
    If I managed to write it down correctly (would have been easier to copy.. hint-hint) then It saved it if it was written as..
    vpn.tunnel.ipsec["{{#VPNTUNNEL}.regsub(\"(IPSEC-.*)(?:\{\d{1,3}\}\"),\1)}"]
    I was following example here https://www.zabbix.com/documentation...ros/lld_macros
    Note, that commas are not allowed in unquoted item key parameters, so the parameter containing a macro function has to be quoted.
      • florian.becker
        • Mar 2023
        Thank you so much! It works now
