Software inventory
  • nikita_lnx
    • Jun 2022
    • 10
    Software inventory
    Hi! I've created a powershell script to collect installed software and add it to UserParameters in the Zabbix Agent.
    My question is - Is it possible to separate output data for using in Inventory tab?
    Now it is completely useless
    Thank you!
    You mean separate this and populate Software A, B, C etc..fields? No, not directly when populating field by item... externally, by script over API, yes.
    Besides, there are limits to those fields... https://www.zabbix.com/documentation...host-inventory
