Trigger dependency on the same trigger, Help!
  • r4pperbr
    • Mar 2023
    Goodnight!
    Could someone help me on how to create dependent triggers over the same IP of a link, I tested it by creating three triggers, one to activate in 5 minutes, another to fire in 1 hour and the last one to fire in 2 hours having the same IP address in trigger as said before, I created this dependency on triggers, but it didn't work correctly firing the 1 hour trigger first. Could someone help me and or inform me if it is possible to create a dependency on top of the same trigger with the same IP or if I am doing something wrong? Below are the images of the trigger dependency configuration. I thank the attention!
