After upgrading from Ubuntu 20.04 to 22.04.2 Zabbiz do not work
  • hsv
    • Jun 2020
    • 14
    Hi
    I have upgraded Ubuntu to version 22.04.2 but now zabbix do not work.
    How to find out why it do not work.
    Zabbix is version 5.0 and when I get the Ubuntu upgrade to work I will continue with upgrading zabbix.
    I use nginx and it answer on the zabbix.domain.com but not on zabbix.domain.com:8080
    the DB is
    mysql Ver 15.1 Distrib 10.3.38-MariaDB, for debian-linux-gnu (x86_64) using readline 5.2
    Regards
    Henning​
  • LenR
    • Sep 2009
    • 1011
    8080 is not the "standard" Zabbix port, that looks like a local customization. It probably would have been in the nginx configuration files. Check if port 8080 is listening, if it is, could be firewall too.
      Are all those versions that came with 22.04 supported by 5.0? There might be too new components also...
      I guess logfiles shoudl be your best friends at this point... webserver, zabbix server, db server...
      • hsv
        • Jun 2020
        • 14
        The problem was 5.0 not supported under 22.04
        Henning
