Dashboard Graph Problems
  • mc kim
    • Mar 2023
    I have some questions while using dashboard graphs.
    # 1
    (Photo 1)
    I used Graph(Classic) item, but the duration seems to be fixed at 1 hour.
    Is there any way to set a time period?
    # 2
    (Photo 2, Photo 3)
    When i use Graph item
    after selecting item pattern, all items are displayed.
    Is there a way to select just a few of them to display?
    Thank you.
    • 4970
    There should be a time filter for your dashboard in top right corner...
    If you use pattern to match multiple ones, then all of them show up aswell...
    • mc kim
      mc kim commented
      Thank you! i solved first problem.
      but is there any way to solve second problem? For example, can i use something like regex to represent only one value?
      Now, when i select one ( Free disk space on $1 (percentage) ), all values ​​appear as in the picture.
    • 4970
    If you only need some of them, then don't use pattern matching in selection... select only those you need...
    If you want to see all of them on graph but only some of them on popup, then that is not possible.
    • mc kim
      mc kim commented
      i got it. thanks!
