Agent2 with Oracle plugin installation
  • jnsvano
    • Feb 2013
    • 144
    As zabbix doc stated, for Oracle monitoring need to "setup and configure Zabbix agent 2 compiled with the Oracle monitoring plugin" (https://www.zabbix.com/integrations/oracle).
    Is it possible to download pre-compiled agent ? Didn't find anything about it.
    You do not need any special compiled plugin. You need to configure existing one.. '
    https://git.zabbix.com/projects/ZBX/...Frelease%2F6.4
    • mcflurry
      • Jun 2022
      • 32
      Originally posted by cyber
      Yep, it's working here too without nothing special.
      • jnsvano
        • Feb 2013
        • 144
        Thank you for replies, seems like yes it is working without nothing special. But what is relation between conf file settings and macroses ? Docs state I can configure following:
        "Using named sessions
        Named sessions allow to define specific parameters for each Oracle instance. Currently, there are only four supported parameters: Uri, User, Password and Service. This option to store the credentials is slightly more secure way compared to item keys or macros.
        For example, if you have two Oracle instances: "Oracle12" and "Oracle19", you should add the following options to the agent configuration file:
        Plugins.Oracle.Sessions.Oracle12.Uri=tcp://192.168.1.1:1521
        Then you will be able to use these names as the first parameter (ConnString) in keys instead of URIs. "
        While I configured all these settings in agent conf file (and macros ConnString), it does not work until I created macroses for all settings (user, password, etc)
