How to configure sending alerts to Telegram
  • Jackson Melo
    • Mar 2023
    Hey guys
    I'm having trouble configuring the sending of Zabbix alerts, specifically in the Script configuration using the Webhook method
    I've looked for some tutorials, but it's not clear which commands I have to put there in Script: var Telegram = { ...
    can anybody help me?​
    • 4970
    You most probably do not need to change anything in script itself. You need to look for all those parameters there, what you want to change... tokens etc...
    This looks quite detailed...
    • mcflurry
      • Jun 2022
      • 32
      And works like a charm, followed that months ago and everything works after first configuration.
      • Jackson Melo
        • Mar 2023
        Even configuring with step by step, I found this problem, do I need to install or change something in Ubuntu Server?
        • Jackson Melo
          • Mar 2023
          Sorry for my personal confusion, I managed to solve it, thanks
