zabbix frontend for el7
  • pelacables
    • Mar 2023
    Dear all,
    I started to install/configure a new zabbix server version 6.4 on Scientific Linux 7 using puppet module from https://forge.puppet.com/modules/puppet/zabbix/readme
    I already faced some issues using that code that I'll report once I manged to finish the installation, but I've faced an issues I cannot solve: I cannot find packages for zabbix-{frontend,web,..} for el7 .
    Looking at https://www.zabbix.com/download?zabb...y&db=pgsql&ws= I cannot find any frontend option if I select el7. If I go for 8 or 9 I do see apache/nginx packages.
    The repos for el7 does not show any frontend package at all: https://repo.zabbix.com/zabbix/6.4/rhel/7/x86_64/
    Where can I find the frontend packages for Zabbix 6.4 for el7 ?
    TIA,
    Arnau
  • Atsushi
    • Aug 2013
    • 2028
    Zabbix official packages do not provide server-related packages for Zabbix 6.4 on RHEL 7. Zabbix 6.4 on RHEL 7 is agent and proxy only. If you want to build a Zabbix 6.4 server, move to a newer version of the OS or another distribution.
      cyber commented
      And even on other distros you probably need to use latest version to run 6.4...
  • pelacables
    • Mar 2023
    Thanks for your answers.
