Hello everyone,
first post, fresh member so I'll try not to make a fool of myself.
Current topology for Zabbix monitoring system:
- Zabbix server in company HQ
- Zabbix proxies installed in every company site (6 proxies, one on each site, located worldwide)
- Zabbix agents deployed on every Linux / Windows server (a bit over 350 Linux and Windows servers)
- network equipment monitored through SNMP (a bit over 200 network components)
- various network terminals / appliances monitored also through snmp (around 450-500 other devices)
Each agent connects to the regional proxy which connects to the main Zabbix server in the company HQ.
What we try to accomplish now:
- we deployed a secondary Zabbix server in the most distant company site;
- we would like to configure a HA cluster with a conditional alerting system
What I understand from HA cluster with conditional alerting:
- a HA Zabbix servers cluster (either using HA proxy, or some internal clustering system (I don't really know if Zabbix has that in place);
- a PSQL HA cluster for the PSQL servers on Zabbix servers;
- all proxies send the same information to both Zabbix servers;
- when the main Zabbix is online and functioning properly, ONLY the main server sends the alerts for problems;
- when the main Zabbix server stopped working for any reason, or if there is a PSQL problem, the secondary server takes over everything, including alerts.
So, basically, I think it can be summed up like this:
- we need a HA Zabbix cluster (active-passive);
- cluster needs to use 2 different PSQL servers also clustered;
- failover needs to be done if either main Zabbix or PSQL server has a problem and the full role needs to be taken over by the secondary server;
- in fully working state, the secondary server only receives the data, but keeps the alerts dormant as they are managed by the main server.
Thank you
Dan
Thank you
Dan
