Web Monitoring with HTTPS
  • nmz
    • Jan 2016
    • 69
    I have setup some scenario with http conn: to use Web Monitor. And it work. But when I try to create scenario with https conn: I just get error result. Error is Failure when receiving data from the peer: Proxy CONNECT aborted. What am I still need to do?
  • bozab1mix
    • May 2016
    • 10
    So we can help you, you might need to provide little bit more information about your request :
    - Version of Zabbix server
    - Distro as well as version
    - Web server logs
    - Web server configuration for HTTPS
    More information you provide, more it will be easy for us to help you.
