Zabbix Cloudwatch Graphs
  • PratapSingh
    • Apr 2016
    • 29
    Hi ,
    Is it possible to display all cloudwatch metrics graph on Zabbix?
    Problem statement:
    1: users want to see all their servers cloudwatch metrics
    2: I do not wish to create IAM for every user
    What I am thinking to achieve using Zabbix:
    1: Configure zabbix to fetch all metrics of instances under auto-scaling groups
    2: If instances are not under any Auto-scaling group then bring all metrics using Name or Environment tag of instances if possible.
    3: Enabling user to view graphs of these server for their zabbix host groups.
    Is there any way to achieve this? I looked up to cloudwatch-zabbix project but finding it difficult to generate graphs. If anyone have done anything similar please share the steps or point me to right direction.
  • jan.garaj
    • Jan 2010
    • 506
    Find the Zabbix projects that match your keywords! 900+ projects
    If you need only graphs, then Grafana with cloudwatch datasource is better solution.
    • PratapSingh
      • Apr 2016
      • 29
      Thanks Jan,
      Yes, I am exploring Grafana, But I am not in favor of using it as it will add up one more tool in my infra to manage and added workload too. I would like to do it using Zabbix if it is possible if not then yep unfortunately I have to go for Grafana.
      • varunmanik
        • Aug 2016
        same issue
        Hi Pratap,
        I need to monitor all EC2 instance matrices without installing agent inside ec2 server.
        Pratap please let me know if you have find something.
        I follow this link
        Contribute to omni-lchen/zabbix-cloudwatch development by creating an account on GitHub.
        and get the result for ELB and RDS but not getting anything in instance matrices.
        Thanks in Advance.
        • PratapSingh
          • Apr 2016
          • 29
          Hi Varun,
          I moved to Grafana for graph and its pretty easy to install/configure. I would suggest the same to you. I am still using Zabbix for server and static service monitoring.
          Thanks,
          ../Pratap
          • varunmanik
            • Aug 2016
            Thanks for quick reply.
            I installed Grafana, and configure it well.
            But not able to see the graph on Dashboard, can you plz help me out in this.
            Looking forward to hear from you.
            • PratapSingh
              • Apr 2016
              • 29
              Hi Varun ,
              You need to add datasource in grafana. You may refer to documentation site "http://docs.grafana.org/datasources/cloudwatch/"
              Thanks,
              ../Pratap
              • varunmanik
                • Aug 2016
                Hi Pratap,
                I found the solution, for monitoring cloudwatch graph without installing agent.
                Please follow this link.
                Zabbix AWS monitoring template. Contribute to ike-dai/zaws development by creating an account on GitHub.
