Zabbix behind Nginx reverse proxy (proxy_pass)
  • brencklen1@southernct.edu
    • Mar 2023
    Hello!
    I currently have Zabbix 6.0 LTS running (Rocky Linux 8, nginx and PostgreSQL) just fine on a basic install. The Zabbix web interface is running at https://zabsvr.fqdn.tld:8080 and working fine with monitoring and alerting via email. I don't have local SSL cert expire checking working, but that's another story.
    What I want to do is proxy the port 8080 web page, so users connect to https://zabsvr.fqdn.tld/zabbix instead of http://zabsvrfqdn.tld:8080. Since I'm already using Nginx, this SHOULD have been a quick change. Unfortunately, I ran into a problem. What I did was enter the very simple config below into nginx.conf under the server section.
    location /zabbix {
    proxy_pass http://zabsvr.fqdn.tld:8080/;​
    I get a login screen, but logging in gives a 404 error. The error in /var/log/nginx/error.log is this.
    2023/03/24 17:26:05 [error] 11299#0: *769 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 10.10.10.9, server: zabsvr.fqdn.tld, request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/www.sock:", host: "zabsvr.fqdn.tld", referrer: "https://zabsvr.fqdn.tld/zabbix"
    10.10.10.9 is the ip of the server, not the client I am running a browser on. I'm not sure if I need to edit something in zabbix.conf, php.conf or nginx.conf at this point, but I have my doubts that its an nginx thing but maybe a simple proxy config doesn't work and it needs other options? And of course, all I find are videos where people have it working, not any that show how to configure it :-) Google searching that error specifically brings me down a rabbit hole of node.js and react.js issues that don't seem to apply in my case. I did install certbot and got a TLS certificate installed from our ACME providor, but I don't think that is the issue. Without forcing 80->443, nginx should still proxy 80->8080, but that gives the same error.
    Thanks for any help, tips or leads on how to solve this! I actually just built a second server following the same instructions and again, Zabbix is working great, just can't get the proxy configured to wrap it up in TLS!
    -Nick​
    • Mar 2023
    After much testing, it was determined that I could set an nginx proxy on another host without a problem. What was erroring out was trying to do nginx running zabbix AND a proxy from 443->8080 on the same host. I am not sure how to solve that problem, but it points to an nginx configuration issue more than anything with Zabbix. I ended up installing Zabbix with the apache server instead, working just fine with 443 TLS.
    • Lawipac
      • Jul 2023
      I have encountered the same problem. For my case it's due to Nginx'd default handling of php and cgi-bin, it tries to handle php and cgi locally instead of forwarding to the Zabbix host/docker
              location / {
                      proxy_pass http://10.0.0.3:8080/;
                      proxy_http_version 1.1;
                      proxy_set_header Upgrade $http_upgrade;
                      proxy_set_header Connection Upgrade;
                      proxy_set_header Host $host;
      #       location ~ "\.php(/|$)" {
      #               try_files $uri $fastcgi_script_name =404;
      #               default_type application/x-httpd-php;
      #               fastcgi_pass unix:/var/php-nginx/1689482424469450.sock/socket;
      #       fastcgi_split_path_info "^(.+\.php)(/.+)$";
      #       location /cgi-bin/ {
      #               gzip off;
      #               root /home/site24x7/cgi-bin;
      #               fastcgi_pass unix:/var/fcgiwrap/1689482424469450.sock/socket;
      #               fastcgi_param SCRIPT_FILENAME "/home/site24x7$fastcgi_script_name";
      #               fastcgi_param GATEWAY_INTERFACE CGI/1.1;
      #               fastcgi_param SERVER_SOFTWARE nginx;
      #               fastcgi_param QUERY_STRING $query_string;
      #               fastcgi_param REQUEST_METHOD $request_method;
      #               fastcgi_param CONTENT_TYPE $content_type;
      #               fastcgi_param CONTENT_LENGTH $content_length;
      #               fastcgi_param SCRIPT_NAME $fastcgi_script_name;
      #               fastcgi_param REQUEST_URI $request_uri;
      #               fastcgi_param DOCUMENT_URI $document_uri;
      #               fastcgi_param DOCUMENT_ROOT /home/site24x7/public_html;
      #               fastcgi_param SERVER_PROTOCOL $server_protocol;
      #               fastcgi_param REMOTE_ADDR $remote_addr;
      #               fastcgi_param REMOTE_PORT $remote_port;
      #               fastcgi_param SERVER_ADDR $server_addr;
      #               fastcgi_param SERVER_PORT $server_port;
      #               fastcgi_param SERVER_NAME $server_name;
      #               fastcgi_param PATH_INFO $fastcgi_path_info;
      #               fastcgi_param HTTPS $https;
      Specifically, I commented out those lines in my nginx.conf for this particular site, and it works as expected.
      • terracenter
        • Nov 2019
        Hi
        On Debian 12 with Nginx repo and nginx vhost zabbix
        vim /etc/nginx/conf.d/zabbix.conf
        upstream zabbix {
        server local_IP:8080; ## Zabbix Web Nginx too
        server {
        server_name zabbix.mydomain.net;
        proxy_read_timeout 720s;
        proxy_connect_timeout 720s;
        proxy_send_timeout 720s;
        # Add Headers for zabbix proxy mode
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Host $host;
        proxy_set_header X-Forwarded-Proto $scheme;
        # log
        access_log /var/log/nginx/zabbix.access.log;
        error_log /var/log/nginx/zabbix.error.log;
        # Redirect requests to zabbix backend server
        location / {
        proxy_redirect off;
        proxy_pass http://zabbix;
        # common gzip
        gzip_types text/css text/scss text/plain text/xml application/xml application/json application/javascript;
        gzip on;
        # cache static data
        location ~* /web/static/ {
        proxy_cache_valid 200 60m;
        proxy_buffering on;
        expires 864000;
        listen 443 ssl; # managed by Certbot
        ssl_certificate /etc/letsencrypt/live/zabbix.mydomain.net/fullchain.pem; # managed by Certbot
        ssl_certificate_key /etc/letsencrypt/live/zabbix.mydomain.net/privkey.pem; # managed by Certbot
        include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
        ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
        server {
        if ($host = zabbix.mydomain.net) {
        return 301 https://$host$request_uri;
        } # managed by Certbot
        listen 80;
        return 404; # managed by Certbot
        That work for me.
