regexp preprocessing with conditional return value
  • trta
    • Jul 2010
    • 18
    I can get these values from item:
    OK LOGIN Completed
    or
    NO LOGIN Error message
    I would like to regexp that by something like
    .*(OK|NO) LOGIN(.*)
    and want to get
    if ok return value \1, if NO then return value \2 (that Error mesage)
    At now, I can get "OK" or "NO" easilly but I don't know how to create something like "if"
    How can I make it please?
    JS preprocessing, I think... regular regex will not do it for you...
    • Hamardaban
      • May 2019
      • 2714
      In preprocessing:
      step 1) "Matches regular expression​" compare with "^NO LOGIN.*". Check the option "Custom on fail​" and output the value "OK".
      step 2) "Regular expression​" "^NO LOGIN(.*)"- output the first group \1.
        Right... 2 steps... stupid me...
