Help on "Log time format"
  • aferraz
    • May 2016
    I use Zabbix for log monitoring but I have a little problem.
    For graph and alarms zabbix use his timestamp instead of the log timestamp tha I get from "Log time format".
    In this case if I stop the Zabbix agent and restart it after 1 hour are taken the old data from the log file but any alarms is notified based on zabbix timestamp which it differs from that of the log file.
    Does anyone know how to use only "Log time format" for triggers and graphs ?
    Thnaks
