Host does not connect to zabbix agent 2 without template
  • markuman
    • Mar 2023
    I've got a strange issue. I am creating hosts using ansible community.zabbix.zabbix_host that works perfectly
    - name: configure zabbix hosts
      community.zabbix.zabbix_host:
        host_name: my.host
        interfaces:
          - type: 1
            main: 1
            useip: 0
            dns: my.host.tld
            port: "10050"
        host_groups:
          - Linux servers
        link_templates:
          - Linux by Zabbix agent
        status: enabled
        state: present
        tls_psk_identity: my psk identify
        tls_connect: 2
        tls_accept: 2
        tls_psk: "{{ lookup('onepassword', 'zabbix.agent.psk') }}"
    When I remove the host and recreate it without a template (or just unlink the template) and add just a web scenario to it, the agent won't become available.
        host_name: my.host
        interfaces:
          - type: 1
            main: 1
            useip: 0
            dns: my.host.tld
            port: "10050"
        host_groups:
          - Linux servers
        link_templates: []
        status: enabled
        state: present
        tls_connect: 2
        tls_accept: 2
    Furthermore, there is no error message. Nor on the client host in /var/log/zabbix/zabbix_agent2.log nor in the server log related to my.host.
    Any ideas what's going wrong?
    Why should it show agent availability if you have no items related to agent? Web scenarios are not executed on host, but on server/proxy. They do not need any agent. Server/proxy will never look for an agent, that has no items...
    https://www.zabbix.com/documentation...web_monitoring
    The steps are periodically executed by Zabbix server in a pre-defined order. If a host is monitored by proxy, the steps are executed by the proxy.
