Zabbix 6.0 HA, configuration and media types problems
  • BEDTr@veler
    • Jul 2022
    Hello everyone!
    I configured Zabbix 6.0 HA.
    I used zabbix-mon-01 and zabbix-mon-02 as zabbix nodes, zabbix-sql-01 as sql server.
    After configuring server according to official documentation - servers switching correctly.
    My main zabbix server is zabbix-mon-01 (10.10.190.101), secondary server zabbix-mon-02 (10.10.190.102).
    If I turn off zabbix-mon-01, web interface over 10.10.190.101/zabbix not respond. I can get access over zabbix-mon-02 (10.10.190.102/zabbix).
    In this way my media types - MS Teams not working because macros {$ZABBIX.URL} saved as value http://10.10.190.101.
    How I can get access to web interface zabbix using only one ip address?
    How I can fix MS Teams notification?
    Thank you for any help.
  • Answer selected by BEDTr@veler at 11-04-2023, 11:34.
    cyber
    Install separate web frontend... I just don't understand this building HA, but leaving 2 possible frontends..
    You can of course make things complicated and use VIP address, what you can move around with keepalived between those 2 servers and configure both frontends to use that VIP. You can do that of course with separate frontend hosts also to gain HA frontend..
      • BEDTr@veler
        • Jul 2022
        Thank you. I don't thought about it for High Availability.
        • BEDTr@veler
          • Jul 2022
          I used service Keepalived for VIP address. All working correctly, acording to this manual
