Widget Graph (classic) 6.4.0
  • Enmanuel Leonis
    • Aug 2021
    • 13
    In zabbix server 6.4 implementation the "classic" graphs do not work correctly, the graph legend does not appear (only happens with this graph).
    OS: CentOS Stream 9
    Mysql: 8.0.30
    Zabbix Server: 6.4.0
    Clean installation, without data only from the zabbix server itself,
    is there anything to configure?
Name:	2023-03-29 14_47_31-Zabbix.png
    Thanks​​
  • Answer selected by Enmanuel Leonis at 29-03-2023, 16:14.
    cyber
    I just saw a similar topic somewhere today... Rocky linux and no legend for graph or something... Solution was relinking fonts to correct place.. Cannot find that topic now unfortunately..
      • Enmanuel Leonis
        • Aug 2021
        • 13
        Thanks for your answer cyber you have helped me to find the error,
        In my case the error was that in the directory >/usr/share/fonts was not the folder "dejavu" which is what the graphic refers to the source, I copied it from an old installation and now I see the data correctly.
Name:	2023-03-29 16_09_08-root@localhost__usr_share_fonts.png
        all this is configured here
        ​ Click image for larger version
Name:	2023-03-29 16_11_08-WorkMeter_DB_KeePass - KeePassXC.png
        After that, the graph looks good.
Name:	2023-03-29 16_14_17-Configuración.png
        Thank you very much
