How to create trigger or trigger prototype for not yet existing item?
  • minri
    • Mar 2023
    I am trying to create template for our FreeRADIUS installations monitoring. I configured autodiscovery rule to discover all the items from the status. And I would like to keep it that way because FreeRADIUS gives out quite a few statistics items.
    And I want to add trigger to check if radiusd is answering the requests. It needs to combine several items. E.g. at very least to check if Accounting-Responses is about equal to Accounting-Requests. But I cannot create the trigger because at the time items for Accounting-Requests and Accounting-Responses do not exist yet.
    So how can I create such trigger?
    • 4970
    If you have discovery with item prototypes, then you just add trigger prototypes...
    • minri
      • Mar 2023
      With trigger prototypes I can easily add trigger per item. And that trigger would react only to that one item.
      What I want is to add trigger which combines several from discovered items. E.g. DISCOVERED_ITEM3 < DISCOVERED_ITEM5*0.90.
        • 4970
        ah ... got the point...
        But I'm afraid you cannot do that via discovery.. As you pointed, discovery deals with a single item at once and does not mix them..
        • minri
          • Mar 2023
          I could do it not via discovery. But anyway Zabbix does not allow to create trigger for the item which not yet exists.
          So the question was about that - is it possible to create Zabbix trigger which points to not yet existing item?
            • 4970
            Nope....you can not do that..
