3Com Switch SNMP
  • Afateminejad
    • Feb 2023
    • 15
    3Com Switch SNMP
    I have a 3com Switch baseline 2952, and I want to monitor via SNMP. CPU utilization /Memory utilization and Temperature.
    But unfortunately I can not find OID and whatever I put it gives this message: No Such Instance currently exists at this OID.
    Can you please advise?​
  • Hamardaban
    • May 2019
    • 2714
    Try https://www.zabbix.com/integrations/hpe#3rd_party
    Temp - .1.3.6.1.4.1.25506.2.6.1.1.1.1.12.8
    CPU utilization - .1.3.6.1.4.1.25506.2.6.1.1.1.1.6.8
    Memory Usage - .1.3.6.1.4.1.25506.2.6.1.1.1.1.8.8
    ALL - https://oidref.com/1.3.6.1.4.1.25506
    • Afateminejad
      • Feb 2023
      • 15
      Thank you very, very much.
      I enabled SNMP V3 on the switch and configured it.
      On Zabbix, I added SNMP V3 to the host (switch) and added Items same you told.
      But there are two issues:
      First, the SNMP symbol does not turn green which means that SNMP 3 is not yet activated
      Second, when I create an item (for example for CPU utilization), it still gives a message: No Such Instance currently exists at this OID.
      Should I enter the same OIDs or do I have to make a special change?my switch's model is 2952.
      Sorry, I'm asking simple questions. Unfortunately, I'm new to Zabbix and I need to study a lot.
      I would be grateful if you could help me​
      • Hamardaban
        • May 2019
        • 2714
        Your questions are more related to configuring and using SNMP - and this is not the easiest thing.
        Please read the documentation on configuring SNMP on zabbix.
        Do everything consistently without skipping toasts and everything will work out.
        But for example, the visibility of certain OIDs may be limited on the switch - you will also need to study the documentation for the switch.
        • Afateminejad
          • Feb 2023
          • 15
          Thank you very much.
          You are right and I need more research.
          Fortunately Problem resolved.
          Maybe it will be useful for someone
          I noticed that the 3com 2900 series switches are the same as the HP V1910-48g switches, and with the OID of HP model, the problem was solved.
          CPU 1.3.6.1.4.1.43.45.1.2.23.1.18.1.3.0
          Temp. 1.3.6.1.4.1.43.45.1.2.23.1.18.1.3.0
          Thank you again​
          • Hamardaban
            Hamardaban commented
            mistake: cpu & temp in you post have same oid
            I will add
            hwLswSysCpuRatio .1.3.6.1.4.1.43.45.1.2.23.1.18.1.3.0
            hwLswSysMemory .1.3.6.1.4.1.43.45.1.2.23.1.18.1.14.0
            hwLswSysMemoryUsed .1.3.6.1.4.1.43.45.1.2.23.1.18.1.15.0
            hwLswSysMemoryRatio .1.3.6.1.4.1.43.45.1.2.23.1.18.1.16.0
            But hwLswSysTemperature .1.3.6.1.4.1.43.45.1.2.23.1.18.1.17.0 -> No Such Object available on this agent at this OID
            Browse A3COM-HUAWEI-DEVICE-MIB: OIDs, tables, notifications, syntax, descriptions and Observium support. The latest baseline.
        • marcelo.garcia
          • Dec 2025
          CPU Usage (1m) 1.3.6.1.4.1.4.3.4.5.1.2.2.3.1.1.8.1.3.0 Percentage (%).Most important for monitoring peaks.
          Memory Usage (%) 1.3.6.1.4.1.4.3.4.5.1.2.2.3.1.1.8.1.1.6.0 Percentage (%).The main value for monitoring memory health.
          Temperature (°C) 1.3.6.1.4.1.4.3.4.5.1.2.2.3.1.9.1.3.1.3.0.1.1 Degrees Celsius.The main temperature sensor.
          Temp.Limit (Warning) 1.3.6.1.4.1.4.3.4.5.1.2.2.3.1.9.1.3.1.4.0.1.1 Degrees Celsius.Useful for creating smart alerts.
          Hardware Status 1.3.6.1.4.1.43.45.1.2.23.1.18.4.2.1.3.0 Text.Returns "Normal" if everything is OK.
          Memory Total 1.3.6.1.4.1.43.45.1.2.23.1.18.1.14.0 Bytes.Total physical memory value.
          Memory Usage 1.3.6.1.4.1.43.45.1.2.23.1.18.1.15.0 Bytes.Value of memory currently in use.
          Software Version 1.3.6.1.4.1.43.45.1.2.23.1.18.1.4.0 Text.Useful for inventory and version control.
