create link map between hosts
  • piero
    • Mar 2023
    Good morning everyone,
    I am happy to be part of this forum.
    I need to know if it is possible to connect the hosts to each other.
    Example I have a camera type host that is down, by clicking on it I would need to know which switch it is connected to.
    Is there a function that allows you to do this?​
  • piero
    • Mar 2023
    Create link between hosts.
    Host father and host son.
    • markfree
      • Apr 2019
      • 872
      It seems to me you are looking for an organizational method.
      You could try using the Maps feature, as it can visually display the connections between your hosts.​
