Zabbix upgrade from 6.2 to 6.4 messing with Custom expressions under Trigger actions
  • Spinat
    • Jan 2023
    After the upgrade i notice the order of the conditions is wrong, and every time i change it to the correct order and saves, it just changes it back.
    Has anyone noticed the same ?
    Heres a screenshot of what Zabbix changes the expression to...
    The correct should be ((A or B or G or F or E) and H) or (C or D)
    ​Click image for larger version  Name:	billede.png Views:	0 Size:	31.3 KB ID:	462173​
  • Spinat
    • Jan 2023
    Bump, i've tried on a new zabbix server, there must be others experiencing this?
    • anandep
      • Aug 2023
      it seems, you simply need to maintain the order or labels while constructing the condition.
