trigger count() using external script
  • KerneL_
    • Oct 2022
    I want to make the trigger if the count of 3 is more than 1 as an error in 20 minutes, then make it as a problem.
    count(/OS_2023/check_website_latency.sh[{$URL}],3m,"gt",1)>3
    And I do have this error : the gt isnt a the good place.​
  • markfree
    • Apr 2019
    • 874
    The example you provided does not seem to match its description.
    Have you tried using the expression constructor?
    • KerneL_
      • Oct 2022
      I tried to use the expression constructor, but it does not what I want.
      The external script is check_website_latency.sh and the parameter I add is $URL
      The problem is when the value is over 1 3 time into 20 minutes, I want a trigger.
        • 4970
        If you want to count during 20m, why do you keep entering "3m" there? Your current expression is "count of values during last 3 minutes which are greater than 1" > 3... Try with "20m"
