Template for Microsoft Hyper-V
  • Maissa DRIDI
    • Apr 2023
    • 13
    I am trying to setup zabbix v6.0 for my project, I have an Hyper-V to monitor aside from the other network infrastructure.
    I already tried the script provided on the website of Zabbix for monitoring Hyper-V Zabbix3.0. https://www.zabbix.com/integrations/hyper-v and it didn't work.
    I would like to know if there is any other solution.
    Thank you in advance,​
  • Nedfox
    • Feb 2023
    On Github it states V5+
    If you want serious answers, ask serious questions, and not "didn't work". Supply error-messages etc.
    • hubertsvk
      • Jul 2019
      • 15
      i have the same problem, in zabbix agent (active/passive) i set timeout to 30 but still in log I have timeout
      Failed to execute command "powershell -NoProfile -NoLogo -File "C:\zabbix\scripts\zbx-hyperv.ps1" full": Timeout while executing a shell script.
      active check "ms.hyperv[full]" is not supported: Timeout while executing a shell script.
      I have zabbix 7 lts and problem is on windows 2012 r2
