No data found on template
  • Xyue
    • Jan 2016
    • 93
    Hi guys,
    I just installed version 3.0.3 last week
    [root@ZabbixWebServer ~]# zabbix_server --version
    zabbix_server (Zabbix) 3.0.3
    Revision 60173 18 May 2016, compilation time: May 23 2016 04:50:56
    I want to assign template to the host. So i choose host, go to template tab and click select. There is no template as it shows "no data found" but when i manually type, it was able to find the template.
    I have a staging zabbix server with version 3.0.1 was working fine and did not encounter this issue.
    Is anyone faced the same issue as i am ? Any solution for this ?
    Please advise. Thank you very much in advance.
  • Atsushi
    • Aug 2013
    • 2028
    The problem seems to have already been reported.
    I think that it is fixed in the next release.
    ZBX-10840
    Zabbix Templates disappear on "Link new template" section
    • Xyue
      • Jan 2016
      • 93
      Hi Atsushi,
      Noted. Any idea when will the next release came out ?
      • Atsushi
        • Aug 2013
        • 2028
        Please wait until the official release.
        If you do not want to wait anyway, please try to make the following changes.
        Guarantee of behavior does not.
        Please take a risk on your own.
        --- /usr/share/zabbix/include/classes/pagefilter/CPageFilter.php.orig   2016-05-18 21:59:37.000000000 +0900
        +++ /usr/share/zabbix/include/classes/pagefilter/CPageFilter.php        2016-05-31 13:33:24.199000000 +0900
        @@ -253,7 +253,7 @@
                        // groups
                        if (isset($options['groups'])) {
        -                       $this->_initGroups($options['groupid'], $options['groups'], isset($options['hostid']) ? $options['hostid'] : null);
        +                       $this->_initGroups($options['groupid'], $options['groups'], $this->_requestIds['hostid']);
                        // hosts
        @@ -390,7 +390,7 @@
                        $this->data['groups'] = API::HostGroup()->get($options);
                        // select remembered selection
        -               if ($groupId === null) {
        +               if ($groupId === null && $this->_profileIds['groupid'] > 0) {
                                // set group only if host is in group or hostid is not set
                                $host = null;
                                $template = null;
        • Xyue
          • Jan 2016
          • 93
          Hi Atsushi,
          Thanks. In this case, I will just wait for the next release.
          Thank you very much.
          • helloworld
            • Jun 2016
            @@ -253,7 +253,7 @@
                            // groups
                            // hosts
            @@ -390,7 +390,7 @@
                                    $host = null;
                                    $template = null;
            works here! thanks so much!
            • taken
              • May 2015
              • 15
              --- /usr/share/zabbix/include/classes/pagefilter/CPageFilter.php.orig   2016-[CUT]
              Thanks working for me too!
              BR TaKeN
