Zabbix_js missing
  • TheBonaZabbix
    • Feb 2023
    • 67
    Zabbix_js missing
    Dear all,
    I've imported the Zabbix Template for monitoring Cisco Meraki on my Zabbix server 6.0
    downloaded from here--> https://www.zabbix.com/integrations/meraki
    In the Latest data I saw
    The error is:
    Cannot execute script: ReferenceError: identifier 'uplinks' undefined
    at [anon] (duktape.c:83869) internal
    at [anon] (function:73) preventsyield​
    Surfing I found
    but on my CentOS 8 I can't find zabbix_js file
    Can someone help me please ?
    Many thanks
    Andrea
  • tim.mooney
    • Dec 2012
    • 1436
    sudo yum install zabbix-js
    Some of the utilities (zabbix-get, zabbix-sender, zabbix-js) have been split off into their own packages, rather than everything being part of 'zabbix-server'. You just need to install the separate package for 'zabbix-js'.
    • TheBonaZabbix
      • Feb 2023
      • 67
      Many thanks Tim !
      Unfortunately installing Zabbix_js did not fix the problem.
      From what I understand zabbix_js is only for scripts testing.
      I was hoping it would make the scripts work properly.
      Ciao
      • Gerjan Wiersma
        Gerjan Wiersma commented
        Hey, Did you ever managed to fix the problem? I have the same problem rn. It feels like Monitoring Meraki with zabbix is a bit painful overall.
    • TheBonaZabbix
      • Feb 2023
      • 67
      Dear,
      unfortunately the problem persist.
      • markosa
        • Aug 2022
        • 107
        What does Test-options return? I mean are you getting any data from meraki? There may be different paths inuse depending meraki versions used, so you may need to adjust template to suit your version.
        • TheBonaZabbix
          • Feb 2023
          • 67
          Dear,
          The Meraki returns tons of data because it belongs to a large organization.
          A little while ago I made a few small changes to the detection scripts to try to filter the returnerd data.
          Something has changed but I still don't understand if the problem is solved or not.
          At this moment I deleted everything and in the early afternoon I will reapply the templates to the meraki host to start from a clean situation.
          I will update the post.
          Thank you!​
          • KevG
            • May 2023
            Any news ?
            • TheBonaZabbix
              • Feb 2023
              • 67
              Hello.
              It’s been a long time, so memories are clouded.
              I don’t think I ever solved the problem.
              I handled the Meraki differently.
              Side Linux:
              I created a JavaScript script that queries the Meraki through the API. I get a JSON file from this script.
              Crontab,once a day, runs the script to get recent data.
              Side zabbix:
              I created an item (external check) that executes a file .sh (created in the Linux server)
              This .sh simply runs the JSON cat.
              Then a discovery rule (with preprocessing) creates hosts with the information contained in the JSON
              I hope it helps.
              Sorry for my english !
              Best regards
              Ciao​
              • markyd85
                • Aug 2020
                I had same issue today running zabbix 6.4.7, if you upgrade template to latest release it fixes this problem
                • KevG
                  • May 2023
                  Unfortunately i'm using Zabbix 6.0 LTS. Don't know if that's matter
                  • shani_pinhassian
                    • Jun 2024
                    have the same issue too. any ideas?
