Zabbix API help
  • ActionParsnip
    • Apr 2023
    Zabbix API help
    Hi I've looked and looked with no joy. I have used the Zabbix API to get the hostgroup of a host
    HostGroupID=`curl -s -H 'Content-Type: application/json-rpc' -d "{\"jsonrpc\": \"2.0\",\"method\":\"hostgroup.get\",\"params\":{\"output\":\"extend\",\"filter\":{\"name\":[\""$HOSTGROUP_NAME"\"]}},\"auth\":\""$api_key"\",\"id\":0}" http://$server/zabbix/api_jsonrpc.php | jq -r .result[0].groupid`
    This returns a numberic value and this can be even used to delete the hostgroup. No problem
    curl -s -H 'Content-Type: application/json-rpc' -d "{\"jsonrpc\": \"2.0\",\"method\":\"hostgroup.delete\",\"params\":[\""${HostGroupID}"\"],\"auth\":\""$api_key"\",\"id\":0}" http://$server/zabbix/api_jsonrpc.php
    Can someone please advise how I can use this HostGroupID variable or even the HOSTGROUP_NAME variable to see if the group is empty, please? If it is empty then I can run the delete command to tidy up. This ultimately is the goal.
    Thanks in advance
    -AndyW
  • Answer selected by ActionParsnip at 05-04-2023, 09:51.
    markfree
    • Apr 2019
    • 874
    You could try the following.
    Copy the script, change the placeholders to your own, make it executable and run it like this.
    ./zbx_del_empty_group.sh [GROUP NAME]
    #!/bin/bash
    SERVER=[ZABBIX IP OR DOMAIN NAME]
    URL="http://$SERVER/zabbix/api_jsonrpc.php"
    API_TOKEN=[USER TOKEN]
    HOSTGROUP_NAME=$1
    PAYLOAD_GET='
        "jsonrpc": "2.0",
        "method":"hostgroup.get",
        "params": {
            "filter":{
                "name":["'"$HOSTGROUP_NAME"'"]
        "selectHosts": "count"
        "auth":"'"$API_TOKEN"'",
        "id":0
    RESPONSE_GET=$(curl -s \
            -H 'Content-Type: application/json' \
            -H "Authorization: Bearer $api_key" \
            -d "$PAYLOAD_GET" \
            "$URL")
    HostGroupID=$(jq -r '.result[0].groupid' <<< $RESPONSE_GET)
    HostsCount=$(jq -r '.result[0].hosts' <<< $RESPONSE_GET)
    if [[ "$HostsCount" = "0" ]]; then
        PAYLOAD_DEL='
            "jsonrpc": "2.0",
            "method":"hostgroup.delete",
            "params":["'"$HostGroupID"'"],
            "id":0
        RESPONSE_DEL=$(curl -s \
           -d "$PAYLOAD_DEL" \
           "$URL")
        echo -e "\nEmpty host \"${HOSTGROUP_NAME}\" ($HostGroupID) deleted\n"
    else
        echo -e "\nHost \"${HOSTGROUP_NAME}\" is not empty!\n"
    fi
    exit 0​
    Note that I haven't treated any possible errors.
    • LenR
      • Sep 2009
      • 1010
      Add the selectHosts='count' option to your first query. That may not be the exact syntax, I use the Python DSL, so don't code JSONRPC directly. That will return the count of hosts in the group, delete if zero.
      • markfree
        • Apr 2019
        • 874
        #!/bin/bash
        HOSTGROUP_NAME=$1
        PAYLOAD_GET='
            "jsonrpc": "2.0",
            "params": {
                "filter":{
            "id":0
                -d "$PAYLOAD_GET" \
                "$URL")
            PAYLOAD_DEL='
                "jsonrpc": "2.0",
                "id":0
               -d "$PAYLOAD_DEL" \
               "$URL")
        else
        fi
        exit 0​
        • ActionParsnip
          • Apr 2023
          #!/bin/bash
          HOSTGROUP_NAME=$1
          PAYLOAD_GET='
          "jsonrpc": "2.0",
          "params": {
          "filter":{
          "id":0
          -d "$PAYLOAD_GET" \
          "$URL")
          PAYLOAD_DEL='
          "jsonrpc": "2.0",
          "id":0
          -d "$PAYLOAD_DEL" \
          "$URL")
          else
          fi
          exit 0​
          Thanks for this man. This really helped. Its just knowing where to put the bits in the code. Inside one brace, outside another and so on. Thanks for the help. This is fab
          -AndyW
          • ActionParsnip
            • Apr 2023
            Problem solved
