fail to start zabbix proxy service
  • newbie70
    • Jul 2021
    I setup my first zabbix proxy on a virtual machine (Ubuntu server 22.04), I follow these instrunctions
    Learn step-by-step how to install and configure Zabbix proxy 7.0 on Ubuntu 24.04 / 22.04 and how to optimize proxy so that it performs better.
    Everything seems fine but when I launch
     sudo systemctl start zabbix-proxy
    this is the result
    Job for zabbix-proxy.service failed because the control process exited with error code. See "systemctl status zabbix-proxy.service" and "journalctl -xeu zabbix-proxy.service" for details.
    The command
    sudo systemctl status zabbix-proxy
    show this:
     zabbix-proxy.service - Zabbix Proxy
         Loaded: loaded (/lib/systemd/system/zabbix-proxy.service; enabled; vendor preset: enabled)
         Active: activating (auto-restart) (Result: exit-code) since Thu 2023-04-06 11:28:02 UTC; 6s ago
        Process: 1589 ExecStart=/usr/sbin/zabbix_proxy -c $CONFFILE (code=exited, status=1/FAILURE)
            CPU: 15ms
    Apr 06 11:28:02 ubuntu systemd[1]: zabbix-proxy.service: Control process exited, code=exited, status=1/FAILURE
    Apr 06 11:28:02 ubuntu systemd[1]: zabbix-proxy.service: Failed with result 'exit-code'.
    Apr 06 11:28:02 ubuntu systemd[1]: Failed to start Zabbix Proxy.
    There is no log file in var/log/zabbix.​
    You can check if you can run that ExecStart command (/usr/sbin/zabbix_proxy -c $CONFFILE) manually. Switch to zabbix user and replace $CONFFILE with real path to config file... you might get some more (error) messages, which can help you to resolve issue...
    • newbie70
      • Jul 2021
      There was an error in cfg file with parameter ProxyConfigFrequency, I fix it but if I try to start the service this is the error:
      sudo systemctl start zabbix-proxy.service
      Job for zabbix-proxy.service failed because the service did not take the steps required by its unit configuration.
      • newbie70
        • Jul 2021
        Solved. There was an error in database, I drop it and recreate another zabbix database. Now works.
        • ehsan
          ehsan commented
          are you using the sqllite databse ? i am getting the same error
