Clone Built-in Template
  • tam481
    • Apr 2023
    I'm new to Zabbix.
    I'm trying to use the "Brocade FC by SNMP" so that I can amend the IFALIAS OID due to the version we're running.
    I tried exporting the template, editing the relevant value, changing the template name at the top as well as generate a new UUID and it keeps asking me if I want to delete existing values which makes me think it's going to amend the original one.
    How do I amend an existing template by cloning it correctly?
    Thank you in advance
    There's "clone" and "full clone" buttons available, if you open existing template for editing... There is no need to export and import anything.. just give a new name to clone...
