Kubernetes : No metrics receive
  • fgreiner
    • Apr 2023
    Hello everyone,
    I'm trying to monintoring kubernetes i follow this :
    https://blog.zabbix.com/monitoring-k...-zabbix/25055/
    The last step is :
    "After a few minutes, you should receive metrics related to the cluster state, including hosts representing the kubelet on each node."
    My issue is no metrics or host is receive
    I'm not sure about the API endpoint link :
    After trying with this one i try some others url with i get some result but nothing change in zabbix.
    Did you know where i can find logs to help me understand where is the probleme please ?
    Best Regards​​
