Try to get UserParameter to return a value
  • Ting-sf
    • Dec 2022
    I am trying to get UserParameter work, I have a host with zabbix agent2 installed, and few UserParameter set up working, but I can not get this one return any value, here is:
    UserParameter=disk1,smartctl -a /dev/sda | awk '/^(Elements).*:/ { print $3 }'
    if I run smartctl -a /dev/sda | awk '/^(Elements).*:/ { print $3 }', it will return a value I want, but somehow UserParameter does not return thsi value to zabbix, it show blank.
    anybody can help?
  • tikkami
    • May 2018
    • 71
    Agent is being run as "zabbix" user, that user might not have permissions to use smartctl.
    • Ting-sf
      • Dec 2022
      Thanks for your reply.
      Yes, you are correct, I add sudo in the command line, it works
      UserParameter=disk1,sudo smartctl -a /dev/sda | awk '/^(Elements).*:/ { print $3 }'
