Zabbix server is running NO
  • alfonso de stefani
    • Apr 2023
    Termine la instalacion en centos con httpd pero me aparexe que zabbix no esta corriendo
    /etc/zabbix/web/zabbix.conf.php
    <?php
    // Zabbix GUI configuration file.
    $DB['TYPE'] = 'MYSQL';
    $DB['SERVER'] = 'localhost';
    $DB['PORT'] = '0';
    $DB['DATABASE'] = 'zabbix';
    $DB['USER'] = 'root';
    //;$DB['PASSWORD'] = 'password';
    // Schema name. Used for PostgreSQL.
    $DB['SCHEMA'] = '';
    // Used for TLS connection.
    $DB['ENCRYPTION'] = false;
    $DB['KEY_FILE'] = '';
    $DB['CERT_FILE'] = '';
    $DB['CA_FILE'] = '';
    $DB['VERIFY_HOST'] = false;
    $DB['CIPHER_LIST'] = '';
    // Use IEEE754 compatible value range for 64-bit Numeric (float) history values.
    // This option is enabled by default for new Zabbix installations.
    // For upgraded installations, please read database upgrade notes before enabling this option.
    $DB['DOUBLE_IEEE754'] = true;
    $ZBX_SERVER = 'localhost';
    $ZBX_SERVER_PORT = '10051';
    $ZBX_SERVER_NAME = '';
    $IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
    // Uncomment this block only if you are using Elasticsearch.
    // Elasticsearch url (can be string if same url is used for all types).
    //$HISTORY['url'] = [
    // 'uint' => 'http://localhost:9200',
    // 'text' => 'http://localhost:9200'
