Last function for discard unchanged value in map (macro)
  • erasedhammer
    • Aug 2020
    • 58
    Zabbix 6.4
    My Item (user parameter to get IP):
    WAN Interface IP Address
    system.ip.wan
    Text
    10m
    Preprocessing: Discard Unchanged
    Macro on map:
    {?last(/fw/system.ip.wan)}
    The wan IP item does have stored data in the lastest data tab.
    I can change the macro to {?last(/fw/system.uptime)} and it shows the uptime.
    How can I display the current value of a item (that is setup to discard unchanged) in a macro on the network map?
    Currently it just says "UNKNOWN"
    Is there some special way to get the macro in the map to display an old unchanged value? Or is it impossible, and I have to delete the processing step on the item?
  • Eduardobbastos
    • Aug 2024
    Uptime:{?last(/{HOST.HOST}/system.uptime)}
    Assim desse modo vai funcionar!
    • markfree
      • Apr 2019
      • 872
      I think your best option is to change the preprocessing step to "discard unchanged with a heartbeat".
      Set it to 1d and your map should display your firewall IP correctly.
