Zabbix active agents stops sending data
  • davidi03
    • Apr 2023
    Hi everyone,
    I have set up 30 active agents running on an old Debian 8 (Jessie) with version 2.2.7. While I know it's an old version, I can't get a newer version to run on our old Debian. The issue is that the active agents send data to the Zabbix server, but it stops after a while. I have to reboot the server or restart systemctl restart zabbix-server to start receiving data again. However, it stops after an hour or so.
    Thank you.
    Log from server with only errors I found, debug level 3.
    Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
  • cyberphantom
    • Dec 2021
    • 67
    Did you solve it? I'm facing the same...
