Information Display on Dashboard
  • vlam
    • Jun 2009
    • 166
    Hi
    I dont know if someone else also asked this before but if not here I go.
    I would like to know is there a way to change the amount of time that information triggers are displayed on the dashboard.
    the default is set to 60min I would like to know if it can be changed to 5min as we only use it for minor changes (Information changes of a system)
    4 Zabbix Frontend Servers (Load balanced)
    2 Zabbix App Servers (HA)
    2 Zabbix Database Servers (HA)
    18 Zabbix Proxy Servers (HA)
    3897 Deployed Zabbix Agents
    6161 Values per second
    X-Layer Integration
    Jaspersoft report Servers (HA)
  • Linwood
    • Dec 2013
    • 398
    No answer but if I could add to your question: Is there any configuration option (vs code change) to change the level of triggers displayed, e.g. to include not-classified?
